There are many examples online of calculations to find the service size based on the NEC.
I am unsure, however, about how the demand factors should be applied to panel schedules, especially in the case of subpanels.
- How are the calculated demand factors applied to a panel schedule when there is a subpanel? Would the following example be correct? There are 4 Fastened in place appliances in a dwelling. A 75% reduction to the Fastened in place appliance load would be made to size the main breaker and wire. Two of these appliances are on a sub-panel. When sizing the breaker and cable for this subpanel, do we take this fastened in place load at 100%?
- In terms of the lighting loads, would you need to
- have a specific square footage associated with each subpanel
- calculate the minimum lighting load based on Table 220.12 and this fractional sqft of the whole building
- Find the demand from the calculated minimum lighting load (if the actual lighting load on the panel is less than the calculated value) and any other applicable loads
