NEC Exhibit 250.1
Richard Leinach
New member
In our departmental meeting today, we got into a hassle about the definition of the short horizontal conductor from the Equipment Grounding Bus to the enclosure in NEC Exhibit 250.1. Is it a ?bonding jumper? or ?equipment grounding conductor?? EGC FPN #1 seems to endorse it primarily as an EGC.
Suppose that ground bar has machine screws into the back box which in the real world it would. Therefore it doesn't need a name.
BTW welcome to the Forum. And the title to your thread should be NECHB...
Many here don't use the Handbook.
Richard Leinach said:
In our departmental meeting today, we got into a hassle about the definition of the short horizontal conductor from the Equipment Grounding Bus to the enclosure in NEC Exhibit 250.1. Is it a ‘bonding jumper’ or ‘equipment grounding conductor’? EGC FPN #1 seems to endorse it primarily as an EGC.
Let's fight about it. Since Chris is wishy washy on this I'll venture to say it's a bonding jumper. Hold on I am sure there will be others taking sides elsewhere. :D
I would also call the screw the bonding screw.
Yes sir. I believe the line in exhibit 250.1 was only to show the can is bonded.
Dennis, when did resi. guys start buying NECHB?:wink:
Edit: spelling
Edit: spelling
I know many resi guys with it but I have never owned one. I played with the idea of getting one but never did. Such is life. I splurged for the CD this year-- big spender huh.:D
Cut and paste from NECH
chris kennedy said:
How do you like not being able to copy and paste the exhibits? Thats real handy!:mad:
?? Why are you not able to cut and paste?
I believe you push the Ctrl key and then drag your pointer over the exhibt...which is then high lighted....copy it ....you do have to paste it to a photo [paint] program...then do a 'save a copy' [as a jpeg].
It is rather convoluted, but you do end up with a jpeg copy of the NECH exhibit.
Cool, I'll try that thanks.
This was a febble attempt at humor people.:smile:
That is how I have done it from the 2002 NECH-CD.
I was able to copy but how do I paste to paint?
