Alwayslearningelec
- NJ
- Estimator
Feeders are essentially everything between the service equipment and the final overcurrent device. The NEC definition of feeder is “All circuit conductors between the service equipment, the source of a separately derived system, or other power supply source and the final branch-circuit overcurrent device.”
If you have a breaker in a panel feeding a disconnect next to the motor I assume the disconnect is technically the final OCPD??
