guggemos
 - Richmond, California
I have a 58 year old house with 100A service. The main is a 2-fuse box at the meter. The 2-60A pull fuses feeds the electric cook top and dryer at 230V. 1-60A pull fuse feeds the 6-ckt house panel (2 spaces, no main) located in the master clothes closet (this meets the NEC 6-switch max rule w/o main). 2-15A breakers feed the lighting in the 1500 SF house and 3-20A breakers feed the receptacles. 1-20 breaker feeds a bathroom wall heater. As you can understand we've always had the problem of tripping breakers.
I want to upgrade the service to 200A with a main panel at the meter splitting the load to the house, range/dryer and garage subpanel. The garage subpanel will take care of the range/oven, dryer, 230V 60A power receptacle and rewired garage circuits and outdoor cicuits. I also want to put an exhaust fan in a bathroom.
Can I leave the (E) house panel in the closet, add the exhaust fan to the bathroom receptacle circuit and unload the kitchen circuits off the (E) house panel adding then to the new panel at the meter?
Can all this work be done w/o adding AFCIs because I'm not touching the bedroom wiring?
