timm333
- Minneapolis, MN
- Electrical Design Engineer
I have a question regarding the grounding of metal boxes for lighting fixtures. Each light fixture has its own metal box, so if there are 10 lighting fixtures in a circuit, there would be 10 metal boxes. The EGC conductor of this circuit would be connected to each of these metal boxes in accordance with section 250.148 (C) of NEC. Also this EGC would be connected to ground in the lighting panel.
Is it better to connect some of these metal boxes directly to the grounding electrode, or is it enough to just connect the EGC to ground in the lighting panel? Thanks
