NEC Mounting Receptacles
As per the 2017 NEC is it permissable for Receptacles to be mounted directly to a panel on the bottom or top of the cabinet itself. If not then what NEC code does this violate?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
If you are modifying the panel without having approval of the manufacturer, then I would say you will have run afoul of 110.3(B).
don_resqcapt19
Illinois
retired electrician
I don't see an issue and it is a common practice. The cabinet that a panelboard is installed in is not required to be a listed product.
