arjo_reich
I swear to god, I'm going to kill this HT guy and claim NEC as my defense. In the last week I've heard him give the following advice - and of course his position is much more respected than mine so my interjections have gone un-noted.
* If the Cat 5e Cable is plenum rated you can run it through all the ducts you want. It's a great way to pull runs if you don't want to pull through walls.
* You don't have to use low-voltage enclosures if you don't want to. Just drill a hole through the drywall big enough for the cable and let it free hang.
* It's perfectly fine to put a set of receptacles on a dimmer to control a set of rope-lights used for isle-ways in a home theatre.
The last one mad as hell because it was downright irresponsible.
