beanland
- Vancouver, WA
The 2014 NEC Handbook defines a PV interactive system as "A solar PV system that operates in parallel with and may deliver power to an electrical production and distribution network." Under this definition, a large PV plant that is built to put power on the utility grid could be an "interactive system", since even a large utility-scale PV system consumes power when the sun is down, it is a both a load and a generator. It is also interactive in that it reacts to events on the grid. (Even a coal or hydro power plant is a load when not generating.)
However, 90.2(B)(5) states that the NEC has no jurisdiction over utility power plants; and a utility is generally defined as an entity that performs utility functions such as generating, transmitting and delivering power to consumers; and it is widely accepted that power plants and substations are covered by the NESC, not the NEC.
So, what can I point to the NEC that unequivocally shows that a PV power plant that is "utility interactive", including the PV modules, DC wiring, inverters, AC wiring, transformers, etc. is not under NEC jurisdiction?
