I am aware that the NFPA at least did have a pdf available of the NEC. I had a few problems a few years ago using it. Does anyone know if there is another place we can get NEC pdf so my guys can use in the field? Mtybee
If you purchase it from them now (I bought the 2017) it works like any other PDF. You can try to upload it to google drive or some other platform so that you can access it from any device.
I had a problem with the File Open plugin that was needed to open it with Acrobat.
The 2001 NECH kept crashing if I tried to put notes in the PDF.
I think that was the first NEC PDF they put out.
Since then, there is no plugin needed. It is just a secure PDF.
