NEC print
Is there NEC rating for CCTV cable? Or does it fall under the CATV/CATVR/CATVP/CATVX FAMILY?
CCTV cable (usually RG59 coax) falls under article 820 and must be listed and labeled with the cable type (CATV/CATVR/CATVP/CATVX).
TABLE 820.154(a) is an easy way to see where each type is suitable for use. CCTV over Ethernet is not covered in 820.
My Thanks........
My Thanks........
CCTV cable (usually RG59 coax) falls under article 820 and must be listed and labeled with the cable type (CATV/CATVR/CATVP/CATVX). Lucky, I'd like to thank you for the information!
Thank you for the information!
