I have a 2500KVA+FC XFMR Sub going in with a 4000A secondary Bus and associated switchgear.
Originally I had 1-4000A MCB, 2-1200A, 1-600A Breakers in the switchgear. Due to costs, I have decided that I can delete the MCB as I am not required to have it per NEC450-3. I have added a high resistance ground to protect the secondary bus. On the 13.8KV side, I have a ground mounted air-switch. So I have a way to lock out the 480V secondary to do work inside the Gear.
Vender tells me that I can not do this per code.
Can I? I thought I could have no more than 6 feeder breakers without a MCB. I have only 3 and maybe 1 Future, so that leaves me wiggle room.
What thought does anyone have on this?
