NEC Requirements for Commercial Grade Garage Door Opener
kayak1
New member
What NEC requirements would my company have to concern themselves with in order to build a comercial grade garage door opener? i.e. power, fusing, enclosure rating and type, grounding, GFCI (if applicable).
What NEC document would I need to follow?
How do I obtain this document?
Gene Colucci (
compliance engineer)
Overhead Door Corp.
Access Systems Division
22790 Lake Park Boulevard
Alliance, Ohio 44601-3498
330-829-3626
330-829-3632 FAX
jim dungar
Wisconsin
PE (Retired) - Power Systems
Re: NEC Requirements for Commercial Grade Garage Door Opener
The NEC is not applicable to the construction of your "opener". The only time you need to worry directly about the NEC is when you are providing installation instructions and branch circuit recommendations.
You need to be more concerned with UL requirements.
One document you may want to use is NFPA 79 "Electrical Standard for Industrial Machinery".
