chimp1
- Palm Bay, FL US
Would a shut off at the motor be required by NEC standards or would a shut off at the motor just be the preference of the operator?
Unless needed for a specific operational safety issue, industrial applications rarely ever put an extra disconnect in sight of the motor.
See 430.102(B), Exception 1.b
ice
Must be a regional thing
Where I am I would say they always put a disconnecting means with an early break aux switch for signalling the control system that the switch is about to open. Also a stop, start station beside it.
For most of my work there just are not many operators out near the equipment anymore so the desirability of having local controls is limited to a few special cases.Comments limited to industrial only:
Interesting. S/S buttons out in the field, next to the motors were in vogue 40 - 50 years ago. It was considered okay to push in the STOP, slide in a pin and use that as a maintenance lockout. That went out in the late 70's. And that was the end of the field S/S unless there was an operational need.
As for local disconnects:
Commercial buildings - yes
Industrial - emphatic No. Unless there is an over-riding maintenance issue, usually non-electrical. Why put them in? No one is going to interupt an industrial process - no sense to it. (Note to nits: Yes, I'm sure someone can come up with a contrived reason)
This regional thing you speak of: Are you thinking East Coast, Northeast only ....
I have not seen much east of the Mississippi - and little east of the Rockies. Still, .....
ice
ice
Having people like that at a refinery makes me very nervous!Just stupid safety for those that have to put their fingers into potentially moving parts etc.
There was a psych study that found that the higher a person's level of formal education, the more likely they were to test a Wet Paint sign though.
Uh .... would you call refinery commercial or industrial? I would call it industrial.
Why put one in? Just stupid safety for those that have to put their fingers into potentially moving parts etc. I find it intresting you consider those with differing view points 'nits'. :roll:
Region? New England.
I just don't get the EEs that do not see the value of a local switch for servicing the equipment unless of course the switch turns off a containment field holding the aliens left over from area 51 in place.
Bob -
That is a disgusting, personal attack - arrogant, demeaning ... (you fill in the rest)
You want to discuss the merits of local disconnects - I will.
You want to throw rocks - I have no interest.
ice
Around here, it is very rare to see a local disconnet at a motor in an industrial application. If there is, it is likely there because plant operations require frequent lockout for cleaning or something like that.Uh .... would you call refinery commercial or industrial? I would call it industrial.
I too work in Mass...
One job we did there was 4 motors on a section of equipment were all fed by VFD's, all about 150' away from the control cabinet. Owner of the facility wanted disco's on the line side of the VFD's at each motor so as to never chance "blowing" the drive by shutting the load off while running. Lots of extra wire and pipe on that one.
