How close can a circuit breaker panel be to a above ground pool? As it sits right now, triplex ug aluminum #2 is coming from a meter\main. They want a circuit breaker panel out about 40 feet from this metering/main point. And from that they would like to feed the above ground pool and some 240 volt receptacle for a RV. A GFCI breaker will be placed for the pool, with an additional ground rod at the new circuit breaker panel location unless only one ground rod is best and the metering\main point.
