Table 450.3(A) of the NEC states that fuses from the secondary of a transformer must be in the same location. I interpret this to mean the same mechanical room I guess??.
I plan to put my secondary fuses of my transformer in two separate mechanical rooms located 150 feet away from each other servicing two separate circuit breaker panels (that service two separate functionally different areas of my building).
Is this a violation of the NEC Table 450.3(A), note 2 as I fear?
I know I have seen this done in other facilities, but those facilites were built in 1945 most likely before this table in the NEC was produced.
