NEC track light power feed question
CallMeChaz
New User
SE Tennessee
Retired Estate Manager
Hey y'all. Never installed track lights (most everything else) and want to make sure I pass inspection first time around. Following my question is a link to the small "live end connector" that I would like to use, to avoid using the much larger, j-box mounted feed. It has a knock-out on the back (ceiling) side that will accept a romex connector and NM cable, acting as its own j-box. It is UL approved.
Is it NEC acceptable to simply run a cable into this through my drywall, whereby it would be only be secured by my track which would be screwed to the ceiling joists. Or do I have to use the style that secures a feed to a "fixture rated box" mounted to my framework for code? (which seems like a gigantic overkill)
LINK: http://www.waclighting.com/product/h-track-13/
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
