Re: NEC vs NFPA
The lines are not blurry here. Any electrical wiring that is contained within a piece of equipment listed by a qualified testing laboratory is not subject to the NEC. Check out 90.7.
If someone field designs and assembles and wires some electrical equipment, said equipment is subject to all the rules of the NEC.
If someone designs and builds the same equipment off-site, then has the equipment evaluated by an approved testing lab (Factory Mutual, UL, etc.), then the equipment is not subject to the NEC, but the hookup and any field wiring is.
If someone designs and builds the same equipment in the field, and has the approved testing lab come out and certify that it is safe, the BO can accept this as well.
NFPA 79 is an excellent standard for designing the equipment, but it is not building code. The inspector can only inspect to the building code. Give him a handle to use. Give him the FM seal of approval. (or UL or CSA, or etc.) But, all building field wiring must comply with the NEC.
Earl
