scotty
- Connecticut
This question has to do with emergency lighting, we were call to add some new remote heads to and existing system,and in order to meet the code we needed a load to go with the low voltage wires so when the lites in that area go out the heads turn on. The problem is a pipe run of 450 feet??,and after 350 feet the emergency lite wires (12 volts) are mixed with line voltage lites (120 volt)and travelers from a three way set to which my load wire is going to be connected. Did somebody already violate 700-15, and will I do the same. I need a interpretation of the code.
thank you scott
thank you scott
