On a typical control circuit protected by a fuse or circuit breaker, where you would have 120vac/125vdc running to a pressure switch and then energizing a solenoid valve, would a ground (in addition to the grounded neutral) conductor be required to be run in the entire circuit and this ground terminated at each device (pressure switch, solenoid valve)? This would be in a power plant environment.
[ August 17, 2005, 02:25 PM: Message edited by: BA Evans ]
