fittings 300.15 i am aving a hard time figuring this out is an acess door required for all fittings
S scottysolar Member Oct 26, 2008 #1 fittings 300.15 i am aving a hard time figuring this out is an acess door required for all fittings
T thorn949 Member Location california Oct 26, 2008 #2 fittings are permitted only on the wiring method for which they are listed. 2 1/2 in. rmc and you use a 2 1/2 in emt connector.
Buck Parrish Senior Member Location NC & IN Oct 26, 2008 #3 I think it means, when you switch from knob and tube wiring to romex. You must use a box. And knob and tube has a material sleeve used as a fitting. Last edited: Oct 26, 2008
