Necessity is the Mother of Invention
Why would he not have flipped the door so that it opened the other way?
It looks like the door has some sort of outer covering extending door depth that would block visibility of the meter with door closed anyway. Definitely a inventive way to have an closed electrical room. It does goes to show that it doesn't matter how little space is in an electrical room, someone is going to store stuff in the dedicated space.
The one side of door jam from the camera angle does seem to protrude into the dedicated working space of the enclosure.
Technically, there is no prohibition in the code against storing thinks in the dedicated space (above and below the equipment), where some but not all of the miscellany in the photo is located, just in the working space.
The dedicated space prohibits permanent installation of foreign (non-electrical) equipment.
But it will still be the electrical inspection that fails. :)
Looks like both inspectors and poco cleared it to me... It was probably framed in afterwards. Had to be afterwards like someone said because the linesguys would gripe about the pulling section screws blocked by the jamb.
Although, no green tag... A few mains have some sort of sticker above it.
