tyha said:
we are doing a commercial garage with 4 lamp T5 HO lights in all the bays. Some of the lights need to be NL/EM. Now it states in the drwings that 2 lamps need to be on during emergency operation as it should but nobody makes a T5 emergency ballast for 2 lamp operation that we can find. They all work 2 lamps on T8's but only one will be in operation for a T5 and it even states that on the wiring diagram for the Em ballast we have. I have not been to the job to see what exactly is going on but one of my guys came in this afternoon and showed the ballast and the wiring diagram to me and it looks as though Im not sure if you can wire 2 ballast to the same light.
I hate to bring up the disscussion here.,,
I know Marc [ MDshunk ] did bring up some idea with the EM / NL system.
but let me step in here for a sec are we talking about the wet location enclosed flourscent luminaire ??
if so just a thought maybe someone did allready make a comment but what if you get in 8 foot
4 lamp verison and get it in 2 balllast verison one with standard electronic ballast and second one with EM ballast?
if that spec do allow it that should work.
a sideline note here in case someone overlook one thing if using the EM or battery back up ballast IIRC some manufacter did forewarn about useing the enclosed sealed luminaires some need some sort of a ventation for the battery unless it is a sealed type.
and the other thing with sealed type some of them may reduce the perforamce in cold sisuation i know some case it may be true if you speced for 90 min back up time with very cold temp if the battery is unheated and well charged it may reduced the amout of the time to run in cold some case in half of the requried time or less.
Just a thought ahead of this in case you will work in very cold spots.
[ i know most enclosed and sealed luminaires should able keep the BU ballast/battery combo warm by heat from the lamp
Merci, Marc
Have a nice New Year !!
