Hi all,
I am trying to reduce the number of converters and wires for a project which will eventually be mass produced. Typically our lighting supplies require 12vDc Class 2 transformers or drivers both hardwired and plug in system.
I also have some phone chargers, ipad chargers that require 5vDC Chargers 3A.
For the prototype I used a single 12v DC supply has its own outputs and used the same supply to power a 5v buck converter. The 12v lights and the ipad chargers both function properly, my question is what other factors do I need to take in account such as a diode?
Should I consider using a diode in between the 12v DC supply and the buck converter? to restrict the return because I am using two different power sources and the second power sources is fully dependent on the first one.
In the event that someone over loads them, am I risking the ipads?
Thank you,
Thank you,
