brantmacga
Señor Member
- Georgia
- Former Child
Architect drew a triangular shaped pendant that matched customers triangular logo; they have three fixture line options (Mark Slot 2, Neo Ray, and a Hubbell fixture), but none of those offer anything other than right angles.
I’m trying to get them to move on from this so we can get stamped submittals and order. But I’m also looking for manufacturers that can build this fixture. Any suggestions? It’s 2” linear LED surface strips that need to have the ends mitered to 45 degree and less angles.
I have considered going to my local welding shop to see if they can build the aluminum frame for me, which I would then have powder coated, and install LED tape lighting inside the channel and mount the driver on top. I would then need to cut an acrylic diffuser to lay within the channel. I believe this wouldn’t require a UL listing because I would be installing a UL listed assembly within the frame.
I’ve attached a screenshot of the drawing I was provided.
