Need DC wiring help
Salguod_22
New User
US
Retired
Hello. I have a solar powered irrigation setup I'm trying to get wired correctly.
The solar part to battery is good. I need help wiring from battery. I have a diagram, but find a way to share it.
I have a Hunter dc irrigation controller that I am using the master valve to trigger the pump through a single pole pump start relay swith.
Battery. +
Pump. Red
Black
Controller. Master valve
Common wire
Relay. Pin 2 - Battery?
Pin 3 - pump?
Pin 5 - coil #1 - ground?
Pin 6 - coil #2
ON/OFF ( pump on/off to bypass controller) in +
Out +
I have paypal and willing to pay for your time. Thank you in advance!
The forum rules do not allow us to assist with DIY projects, try diychatroom com
