Need Foundation vault for oil filled customer owned pad mount transformer?
zemingduan
Philadelphia,PA
Electrical Designer
Do you typically require a foundation vault for oil filled pad mount transformer? Or it is just mounted on a concrete pad on grade? This is not a utility transformer. It is just a customer owned transformer. I know some utility companies such as in our area PECO specifies foundation vault for PECO's pad mount transformer.
Thanks!
If the transformer is of any size it needs more than a slab. Have seen a number of slabs where one side sunk enough that the cooling oil could not circulate.
Up here it is not uncommon to find a few pier/footings under a basic slab. We rarely see vaults.
