I figured that would get your attention because I used to write famous headlines. ["McGovern Sweeps Massachusetts"]
Anyway this is the problem: I plugged my Makita battery charger into a supposed 115 volt source attached to a spider box and it immediately blew up. Well it made a pop and released maybe an ounce of white smoke. I investigated with my volt meter and got readings like 179 volts and more. It turns out at it was plugged into a 240 volt outlet on the main spider box and was jury rigged with the white neutral attached to the ground prong. And the ground wasn't very good.
Mow I know that we have fuses and circuit breakers which protect against over amperages. Surge strips and the like seem designed for transient over voltages. What I would like is some simple device which would cut off instantaneously at say 140 volts or over.
Any Teslas out there?
~Peter
~Peter
