Need help finding a replacement CB
I have a older sylvania BC40200 200 amp entrance panel. I'm installing a whirlpool bath/steamer that requires a 1 pole 30 amp (with 30mA ground fault). I can't find anyone that sells sylvania around here or on ebay.
Is there a cross reference list somewhere that will give me alternatives?
You say you are a technician for a power company. Are you an electrician or a 'do it yourselfer' working on your own home? I also wonder what a powerline technician does? :confused:
I am an electrical mechanic but the common description is powerline technician. I work on high voltage transformers and breakers 15kv up to 345KV. In the winter I mostly do revenue metering for large industrial customers.
I am renovating my house so I am not familiar with the residential equipment but its not rocket science. I just wanted to know if there is another make or model of ground fault circuit breaker that will fit in my house panel. On the panel nameplate it says it will take type QBHG ground fault breakers but I can't get them locally here and I think I read somewhere on the net that they were deiscontinued. Mostly GE and SquareD are the popular brands around here.
