Joseph Wojcik
New member
- Durango Colorado
I have 2 questions i AM STUMPED ON. Any help would be greatly appreciated.
A 2 phase 460 volt wye pump service with no neutral load requires a) a grounded service conductor be run to and isolated from the service disconnecting means. b) a grounding electrode conductor connected to the service disconnecting means c) a grounded service conductor be run to and bonded to the service disconnecting means d) no Adittional grounding or bonding.
Next is 4/0 AWG 75 Degree C aluminum transformer secondary conductors shall be protected at not more than a) 175 amperes b) 200 amperes c) the calculated load connected to transformer d) not required for multiphase delta-wye transformer secondary conductors
I dont know where to even look.
