mkgrady
- Massachusetts
I'm getting ready to install lighting in a new warehouse addition for a commercial heating contractor.The addition is one open room 63'x50' with the bottom of the barjoists at 13'. In this room will be an area 50'x37' that will be mostly bulk storage with pallets of stuff stored until a job is ready to be started. The remaining space of 50'x26' will consist of typical storage shelves for small parts. The shelves will be about 7' high and be placed back to back. Figuring some of the stored materials will be up to 3' tall that puts the storage space up to 10'. It will result in having six 26' isles running between seven rows of shelves.
My local supplier's first suggestion was to use four foot, four lamp T5 flourescent. It seems like a bad choice.
Let's say I use six of those in the large area (I have no idea if that is the right amount). Because the fixtures will mount at 13' that will put a ton of light under each fixture and not very much light between the fixtures. Doesn't seem right.
In the shelving area, I would need to put the fixtures above each isle and I would think at least two fixtures per row would be required and maybe three for a total of 18 in this area. That seems like you would have to wear sunglasses yet one fixture per isle would result create the same problem as the bulk storage area.
Any suggestions would be appreciated.
