charlie tuna
- Florida
i'm in the middle of a problem that i need some advice figuring out how this d.c. contactor works.
this is a big 4160 volt - 2500hp - starter - that pulls the contact vertically up thru a right angle hinged bracket by the function of a coil the size of a football! the contactor voltage is 110 volts D.C.! i just had the coil rewound because it failed (blew up). upon installing the new coil it pulls in and then chaters like it doesn't have the strength to hold the contact up!
i can't have this since it controls 4160 volts to a big chiller unit. connected to the coil is a siries of capacitors and two ceramic coil adjustable wire wound resistors. it also has an auxillary contact. can anybody tell me whats wrong or how this circuit works?? capacitors in a d.c. circuit are probibly to help hold the voltage up for the initial action of the coil???
thanks, charlie tuna
