Long-time lurker, finally joined because I'm wiring my first gas boiler and need advice with wiring the circulators. I've never touch a gas boiler before but am trying to take on the task for a friend. Its a Burnham Series 2 gas boiler with 2 separate zones. Thermostats are heat only (two-wire). I have all the wiring done besides thermostat connections and the Taco circulator connections.
I'm not sure which/what to hook up. The manual is a little confusing since it lists several wiring diagrams and is unclear. Has anyone ever wired these or think you could help me figure it out?
Also (probably a stupid question) but do I need a aquastat? :dunce:
Hopefully these pictures will help:
"DHW Circulator" - factory capped off
"system circulator" - factory capped off
"Thermostat" - 2 yellows
Thank a lot, I greatly appreciate any help!
