jango
Hello,
I need help deciphering the wiring diagram for a 240V sauna unit that is controlled by a Mercuri Digital Control. If you look at the picture of the diagram, I see one of the two 240V legs coming from the power supply connects to L2 on the Mercuri Digital Control. The other leg from the 240V power supply is what stumps me??? I see it goes directly to the H.L. (High Limit switch) which is located inside the sauna junction box area. It runs in series through the H.L. and back to the relay but before connecting to the relay it is in series with a 1 amp 240V in-line fuse. My confusion is, with the sauna drawing 37 amps at 240V, wouldn't the 1 amp 240V in-line fuse blow immediately? Any and all input on this would be very much appreciated. Thanks!
