Need help with cross reference between 2002 and 2005 NEC
lew3611
Hey guys,
I am taking a 2002 practice exam and trying to use the 2005 code book. My questions are 1.) where would I 500-3(d) of 2002 in the 2005 NEC? Also, 250-2(d) of 2002 NEC in the 2005 NEC? I came up with 344.28 Reaming and Threading and 250.4(a)(5) Effective Ground Fault Current Path, respectively. However, on the 344.28, there was no mention of anything about (NPT nor SPT type threads??????? Please help.
It appears the references you cite are actually 99' NEC sections not the 2002.
Anyway, 500-3(d) can be found at 500.8(D) of the 2005 NEC, and 250-2(d) is indeed 250.4(A)(5).
Annex F on page 728 or the 2005 NEC if that helps. It's a cross reference of 99 02 25 NEC's.
