- Tennessee NEC:2017
- Semi-Retired Electrician
I have a motor that I need some help on the internal wiring.
I had to remove the connection plate in the (pecker head) wiring compartment.
I tried to write down the wire colors and placement before I took the leads loose, but there were two wires that came off before I could see them.
The motor is dual voltage, 115V or 230V.
There is a slide switch that you slide to whatever voltage you are wiring it to.
The back side of the slide switch is where the connections are and where the two wires go that I don't know where connect.
Looking at the plate as it comes goes onto the motor there is 2 rows of 3 connections.
The top row has, in this order, yellow-white-orange.
Those are correct.
The two missing wires go on the 2nd row. There is three places to connect but only need two of them.
The two missing wires are what looks like red, and another yellow wire.
The yellow wires show continuity so it shouldn't matter which one I use.
Also, the motor has a capacitor which I assume is a start capacitor.
Here is a picture of the name plate if it helps.
Any help on this would be appreciated!
