bure961
- Farmingham, MA
I could use some help with Altivar 61 vfd rated for/using 75 hp motor. There are 4 units operating at different times each having a 75 hp motor/pump, 3 of the 4 run at a cool temperature about 80f but one is running much hotter about 150f I am told. When it was checked it was running at 45 hz. drawing 45amps. 380 volts on output of drive. Drive is rated for 380 - 480volts. Temp readings done by operator using cheap point and shoot hand held gun type tool.
Each pump / motor has a coolant or antifreeze inside . All were checked and contained the coolant. Amp readings were almost identical when running at the same speed. Motor was never megged . And I am told never tripped out after operating for over 24 hrs. or more .
Does anyone have an idea what could be causing the difference in temp ? All setups are less then a 1.5 yr old. All run at different times. Running times change for each motor. When problem motor is running it takes a few hours of operation before it gets hot. Checked for restriction of flow, found none if this helps. Thanks for anyone with help.
