Need motor info ASAP
jgmcfps
Alabama
I am out of my office and trying to do some research on an existing situation. Need information regarding a specific frame and enclosure for a motor. Need details for the following:
Frame 184T
Enclosure TEFC
Need info ASAP. If possible, please also reply directly to me at jgmcfps@cneti.com. THANKS!!!!!!!
bphgravity
Florida
Re: Need motor info ASAP
That isn't much to work with, but I believe a 184T frame is for up to 5hp or maybe 7.5hp. It is most likely 3-phase, 230/460, 1745/3450-rpm. The TEFC stands for Totally Enclosed Fan Cooled.
Hope this helps! :)
roger deas
North_Carolina
The frame (184T) information is simply frame diminsions and if you are at the motor you can simply measure it i.e. center of shaft to bottom of base,(4 1/2") motor housing bolt patern, (45deg from center line thru shaft) mounting plate hole diminsions, (5 1/2" along length X 7 1/2" looking at end of motor) etc...
This probably is not what you're after, but as Bryan said, you haven't given much useful information.
Roger
[ May 02, 2003, 01:44 PM: Message edited by: roger deas ]
canman
If you will do a search for nema motor frame dimensions you will find all the info you need on this subject.I searched yahoo and came up with some very nice sites.
