rkrieger
I know I should probably know this, but I would like someone to explain how to hookup the following circuit. A school shop wants a "power disconnect" system in which two "panic" buttons located in the shop if pushed, will dump a panel in which all circuits fed by the panel will become de-energized. OK, a tap is taken from a CT, fed through a disconnect, then into a magnetic circuit breaker, then to the dedicated panel.
There will be two E-stop locations and one location with a keyed switch to reset system. E-stops can be re-set by twisting them and pulling out. Key switch is a momentary contact and spring release.
I would appreciate a schematic showing the control circuit. The wiring of the disconnect, magnetic circuit breaker (other than the coil circuit) and the panel is not a problem. Just the control circuit of the circuit breaker.
Thanks in advance for your help.
RLK:-?
RLK:-?
