IrishRugger
Back in the spring of 2006 we finished a new home for a client. It was roughly 4000 sq ft custom style home. In my original proposal included was a circuit for a spa with disconnect and wiring from the disconnect to the spa. During the rough in I ran 6-3 romex and mounted a CH Spa disconnect on the exterior of the home. At the finish of the job the concrete padio from the walk out was poured. The home owner had a spa that he wanted to use but had to install new pumps and other components and was also entertaining the thought of a new spa. So at the end of the job there was no spa used or new to hook up on sight. Two years later (this summer) the home owner got his used spa moved to a location on his patio. This location was all the way to the end of the patio approximately 20 feet away. He called me and asked me to wire his spa. I went to look at it he told me that he wanted to run the conduit under the landscaping I then hand dug in 18" deep under the landscaping (very neatly & carefully) laid in PVC from the disconnect to an LB then ran flex from the LB to the control panel pulled my conductors for the circuit. Then I very neatly filled my trench and very carefully laid the riverstone back on top being sure not to disturb any plants. Then terminated the conductors on the GFCI breaker in the disconnect. I left the terminations off on in the control panel and taped up because he had not yet installed the new pumps or other components. I left the breaker off and taped a note on the inside stating to leave off untill he installs the new pumps and components. I then sent him an Invoice for materials and labor for $339.49 to hook up the spa on the invoice I stated in detail what needed to be done and said I would return at no charge to terminate the control panel and energize the spa when he installs the new pumps and other components. I never got a call to energize the spa. Sixty days later he sends me a check for $150.00 with a note on the check that says he thought that the hook up of the spa was included with the price of the house. I feel this is obviously a misunderstanding and miscommunication on both of our parts. I can see his point, although I never expected the spa to be located as far away as it was at the time I made my house proposal. I cannot remember if we ever did discuss the location of the spa before, during or at the finish of construction. My instinct tells me to credit him the full $339.49 and give him his check for $150.00 back to him, but a little voice tells me that I am entitled to some compensation for the work I had to do. I have reviewed his file and cannot find any type of note of a conversation regarding the location of the spa. I keep notes on all changes and other stuff and keep them filed per project. The customer and I have allways had a good relationship I do not want to jeopardize it. Then again he has used my compeditor to do wiring in his office in the past (between his house being finished and this summer when I hooked up the tub). Sorry about the long post but what would you guys do to resolve this dilema. Also this customer is my Life Insurance agent.
