BobbyBJr
- Upstate, SC
Hello,
I am a hvac service tech who has recently passed our state electrical contractor's exam and I need some help. I have a customer who has a straight cooling unit and they want to do away with the electric duct heaters in the ductwork in the building and have us put electric heat strips in the unit on the roof. I have calculated that they need 56kw of heat for the area. I then took the 56kw and calculated the load to be 155 amps. I got that by dividing the watts by 208 x 1.732. It is three phase. I have a 1/0 wire feeding up through the roof into the bottom of a 100 amp disconnect that is fused at 70 amps for the cooling unit. When I look at table 310.16, I see that 1/0 is good for 150 amps before any derating. The problem is, the boss and the customer both want me to use the 1/0 wire to feed the heater and I have refused because I don't think it is large enough. I think that since it runs on the roof for even a short distance, some derating should be considered. If I just use 120 degrees on the roof, the value is 0.75 of 150, but it was mentioned that the heat won't be on when it is 120 on the roof. Actually, the heat will only be running when it is below 70 and when you use the 1.05 mutiplier, the result is 157.5. Am I close on this? I know that passing the state test don't make me an electrician, but I am trying to do the right thing. I don't think the wire is large enough and want to run a 3/0. Any advice or suggestions will be appreciated.
thanks,
Bobby
thanks,
Bobby
