southernboys
hey guys buddy of mine just bought an instant water heater. the questions I have are its rated for 55 amps so Im going to pull 6-2 to the unit put it on a 60a breaker. Do they make a 60a plug that I can use as my within sight disconect. his water heater is located in his kitchen so trying not to put a subpanel in. also the previous owner built a roof on top of the existing roof so no attic space. I plan on running uf or nm through the rafter outside that are hidden by vinyl siding however I have to turn down the side of his house to get to where his water heater is located. Im wondering does this by code have to be ran in conduit or can it free wire if I follow the contour of his house. If I have to run it in conduit can you guys sugest a way to pull it through 20 ft of conduit with 2 90s and a saddle in it thinking pvc conduit here. also what size conduit would you guys use or would you mount 2 jboxes one abovbe the vinyl siding and one in the wall and pull thwn between those 2 boxes and flex back out with nm or uf thanks
