spurlockda
- Nevada
Hi folks,
thanks for reading my query. I am working on an expeditionary airfield and we have a genny supplying 120/208 240/416 Volts 4 Wire, 3 Phase and I am powering a tower module with the associated electronics as well as an OpsCen/Command and Control module. A lot of the equipment (most actually except the radars) are running 120 VAC single phase. As you can imagine, clean power is critical to the electronics. Plus we have a second 30kW, 120/208 240/416 Volts 4 wire, 3 Phase backup genny that I would like to run with an auto bus tie so that in case of an emergency or unscheduled shutdown of the pri genny, the backup will kick in automatically with very little to no interruption of service.
i've talked to some folks who are not the real experts like you all and they are telling me that the best way to get single phase is to convert it to DC and then to single phase AC. They are saying that will automatically filter the power?????
Any guidance on where I can find the correct solution or build a solution would be greatly appreciated.
Thanks again,
Thanks again,
