chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
How can I print one post from a thread?
Thanks
Thanks
Go to "Thread Tools" at the top of the thread.
Choose "Show Printable Version"
Use you mouse to highlight what you want to print, choose "Print Selection" and your good to go.
Bob, once I highlight, where do I find 'print selection'?
symbols.
Simplest method of all: highlingt what you want directly in the thread, hit Control C (copy), open Notepad, hit Control V (paste), edit if you want to change anything, then select Print from the Notepad's File dropdown menu.
You call that simple???
Simplest method (even simpler than ceknight's):
Right-click on post number and choose Print Target in pop-up menu. Click Print or hit Enter key when Print dialog appears.
Nobody's going to ask Chris what was to battle and who won???![]()
easier than that would be instead of pressing control C or V just right click after you've highlighted it and select copy, then open your notepad and right click again and select paste!Simplest method of all: highlingt what you want directly in the thread, hit Control C (copy), open Notepad, hit Control V (paste), edit if you want to change anything, then select Print from the Notepad's File dropdown menu.
