emiller233
- pittsburgh, pa
- Controls-Automation engineer
When a 480vac 3-phase motor is mounted onto a rubber isolation/dampening bar (for vibration), do we need to run a ground conductor from the motor, across the rubber dampening bar, and onto the skid where this is mounted (picture attached w/ red arrows to the isolation bars)
The motors are just wired back to terminals inside of an enclosure (that is also mounted onto the same skid) thru rigid conduit and LFMC, where the customer will land their wires. if so, do we just follow table 250.122 for sizing?
motor dampening/isolation bars
http://www.ldi-industries.com/display/router.aspx?docid=42&blockid=1&injectedid=1885&
