I'm looking for leads on where to purchase a 120 VAC single phase input transformer with a 3 phase secondary. The 3 phase voltage can be as low as 6VAC per phase so long as I can load it to 3 amps per phase. (If I can only get a 120 in and three 120's out I will be stepping the voltage down to 6VAC for saftey purposes.) The phases need to be near 120 degrees +/- 10%.
This transformer will be used in a test fixture to simulate 3 phase motor power. The device I'm testing only needs to sense the presence of current at the various phase angles. No real work will be done with this transformer/voltages.
Any leads?
Any leads?
