I recently encountered an installation of a outdoor ATS in which the electrician punched a hole in the top of the NEMA 3 ATS enclosure,
using back to back PVC terminal adapters he connected the bottom of the meter pan to the top of the ATS,
No sealing locknuts or sealing washers were used.
Instead a Large Glob of Ductseal material was used to prevent moisture from entering the enclosure.
I would have used a myers Hub or sealing washers and locknuts to prevent any water intrusion.
I feel that by compromising the weatherproof top plate of the enclosure, a better method of sealing the enclosure should have been used.
I feel this is a violation of NEC 110.12 and 110.12(c). I hate to use this article, but i feel the work was done poorly.
If anyone has a better Article to cite i welcome your opinions.
Thanks.
Thanks.
