HenryA
New member
- kutztown,pa
We are possibly expanding our existing walk in refrigerator by removing a wall and building it out to add space .When that happens the panelboard which supplies the evaporators and compressors would now be part of the inside of the box. I was not able to find anything on if a standard Nema 1 panelboard is acceptable in a case like that or if we would have to change it out to a Nema 3r or greater. Or is that panel able to be located in that environment at all. The temperature inside the box is between 36 and 46 degrees. any help is appreciated. thank you
