Re: NEMA vs IEC Starters
NEMA starters are more rugged, reliable and repairable. IEC are delicate, dainty and destructible. I have had a lot of problems with IEC starters overheating, you need to oversize them. IEC starters are designed with about 300,000 operations and NEMA with millions
The biggest issue with IEC starters is they have to be protected with current limiting fuses otherwise they will be destroyed on a short circuit, you just can't always replace a NEMA with IEC.
Having said that, I do prefer the IEC overloads, they are more sensitive on phase loss, and are class 10 ambinent compensated, and heaters are part of the overload. I use NEMA starters with IEC overloads.
