charter188m
So I just recently did 2 underground services where the meter was more than 6' away from the panel, so obviously I installed the weather proof disconnect. Now figure this, one passed the other did not. Absolutely no different, one failed cause I ran SEU between disconnect and panel, the other one passed. Both these serv ices are located within about 5 miles of each other. The ispector told me I needed the ground on the one that failed, I can understand this however what if the disconnect is now bonded? Does it even need to be bonded? Cant make heads or tails from the d*** NEC, I need to spend hours there to find 1 d*** thing, any help would be appreciated.
Regards
Charter188M
(Moderator's Note: Edited to remove potentially offensive language, and moved to the Grounding and Bonding area.)
[ May 27, 2004, 09:50 AM: Message edited by: charlie b ]
Regards
Charter188M
