No. Have them correct it.![]()
I think y electrician is not so great, or he is trying to make work. But I am not sure. THis is a picture of my main electrical panel. In the top right side there are grounds and neutrals on the same buss bar. Is this ok?
It is a main lug panel with a 4 wire feeder, including an EG which appears properly installed.Image doesn't open for me however EGC's and neutrals can be on the same bar in the main service enclosure.
So it's not the service enclosure, thanks.It is a main lug panel with a 4 wire feeder, including an EG which appears properly installed.
In a related story...Unless it is a main panel without a main breaker then the neutral and grounds are fine together but the panel would need a main breaker. In either case the panel install is noncompliant.
Now is the panel really installed sideways as shown or is it upright. Canada allows sideways but the IP address does not show Canada
There's more to it than that. The two bars are physically tied together so they are still one bar. With that said the forum rules do not allow us to assist in DIY projects.Hi guys... It sees I am wrong about this being the main panel. There is a single breaker in a box out by the electrical meter. I think that is considered the main panel and this becomes a sub panel. So I think I need to move the ground wires from the right side buss bar to the grounded buss bar!
This site is designed for:
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
- Electrical Contractors
- Electricians
- Engineers
- Inspectors
- Instructors
